mouppe
 - Feb 7, 2010
I recently got hold of some Vlies abrasive pads from the UK and thought I would write a short review on their use as they are currently NAINA and you don't hear much about them. However, since the Surfix oil applicator was introduced in the rest of the world- and it may make its way over here at some point- presumably these pads which are used in conjunction with finishing an oiled surface may make their way here too?
The Vlies abrasives are available in NA in various grits, but these Vlies pads are different. The green Vlies sanding pad is similar to a Scotch pad and is used to work the oil into the wood. You then follow up with a white polishing Vlies pad to matt the surface, similar to using steel wool.
My workbench needed refinishing which is the perfect project to experiment with these pads.
The workbench before any surface prep. Lots of spills, stains, knife marks, gouges etc.
[attachthumb=#]
[attachthumb=#]
Using the Rotex 125 in aggressive mode, I sanded the surface with Rubin 100, 120 and 180.
25 minutes later...
[attachthumb=#]
[attachthumb=#]
Then I switched to the ETS 125 (random orbit sander) and used Brilliant 2 220 and 320.
11 minutes later...
[attachthumb=#]
[attachthumb=#]
Now it was time for the green Vlies sanding pad. I used it on the ETS 125 just because it is more comfortable than the Rotex, but you could use the Rotex too. I gave a generous coat of Danish oil to the entire surface, let it soak in for a couple of minutes, wiped off the excess with a clean cotton cloth, then worked the oil into the surface on speed setting 3-4 with the ETS 125.
[attachthumb=#]
10 minutes later, the surface was really nice and oily smooth. I have to let the finish cure overnight then I will return with the white Vlies and another oil coat.
[attachthumb=#]
[attachthumb=#]
So far I like this product very much. It takes a lot of the mess out of oil finishes. The pads are not cheap at around $3 each, but it would seem they last a long time. (I actually threw the pad away because I don't like to leave oily pads in the workshop, but it certainly had a lot more life in it.)
[attachthumb=#]
[attachthumb=#]
25 minutes later...
[attachthumb=#]
[attachthumb=#]
11 minutes later...
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
