leakyroof
- Mar 23, 2011
Not on Topic, but yeah, I miss Seven Corners as well... [crying]TSO Products said:just found the item:TSO Products said:I hate to recommend something other than a FESTOOL based solution but I need to share my successful experience at the end of many not-so experiences:
3M ScotchBrite started offering a combination ceramic/aluminum oxide abrasive encapsulated in plastic.http://solutions.3m.com/wps/portal/3M/en_US/3MIndustrial/Abrasives/Products/~/Scotch-Brite-Radial-Bristle-Brush?N=7581714+3293242167&rt=rud#variantView
I have used this type of abrasive in another version fitting the threads on my Milwaukee 4 1/2 angle grinder.
It flexes and follows contours. It does not load (!) up at all. Leaves the metal smooth and bare shiny and ready for etching / priming and coating with your finish.
if desired I will go find my abrasive and submit a picture. Last time I used it to de-rust a just purchased used and badly abused, cast iron band saw table with rust, paint and glue residue.
Hans
'https://www.zoro.com/scotch-brite-bristle-disc-45-in-dia-34-in-trim-80g-24242/i/G1290161/?gclid=CjwKEAjwgo6_BRC32q6_5s2R-R8SJAB7hTG-4V_m0rfq1QbOU9o2M60M2LYu-ZlipbJ25qm1tY5WKRoCG4jw_wcB&gclsrc=aw.ds
SCOTCH Brite Bristle Disc is using an abrasive offered in the disc version shown on the link, also in smaller diameters to fir the ROLOC style 2 inch discs on an air angle grinder and all kinds of other configurations.
If your time and the end result means anything, you'll go this route.
I bought my first one at SEVENTH CORNER HARDWARE in St Paul. Bob, you know Chuck Reese never recommended anything that didn't work (miss that place... and their experts)
Hans
