I have not worked with Sapele before, but will be doing a couple of bookcases in a while.
I have been experimenting with a few finishes.
What I have concluded is that I will be topping it with water based poly, and prefer the look/feel with a grain filler. Also, I like the color of super-blond shellac on it better than garnet shellac.
I have also tried to first put down a few coats of tung oil.
Maybe I am mistaken, but I feel I should be seeing a deeper, richer color with the tung oil first, then shellac (then grain filler, then poly).
But really, I can't see a difference if I omit the tung oil. Both look real good, really glisten, change colors as I change my viewing angle, but I don't see a difference.
Maybe I need larger sample pieces, or there is a problem with my procedure, but is this consistent with what others have found ? See photo of samples below. The upper piece has tung oil base.
