- Jun 25, 2016
Save 10% on our newly expanded selection of JessEm's innovative measuring, marking and safety products at TSO.
Clear-Cut FLEX Stock Guides
JessEm's FLEX Stock Guides are a cost-effective way to upgrade the safety and cut quality of your contractor saw or router table. Crafted from high-quality glass-filled Polyamide, these stock guides maintain all the essential features of their router table cousin, ensuring smoother and more precise cuts while securely holding your work in position.
Clear-Cut Table Saw Stock Guides
A precision tool designed to elevate your table saw experience and deliver unparalleled control and safety while achieving flawless, meticulously smooth cuts. With these innovative stock guides, your workpiece is securely held in place, ensuring superior accuracy and reducing the risk of accidents.
Paralign Double Featherboard
Revolutionize your setup with this innovative featherboard that streamlines parallel adjustments to your work while securely clamped to your table or fence.
Stainless Steel Dowelling Jigs
This versatile tool is designed to cater to the needs of both weekend hobbyists and seasoned professionals, offering multiple solutions for drilling impeccable dowel holes in your workpieces at an affordable price.
Stainless Steel Tool Setting Gauge
Set the height of your table saw blade, router bit, set the depth on your drill press or even the fences on various power tools.
[size=18pt]Discover More JessEm Products
What else is happening at TSO?
JUST RELEASED! MFT/3 Router Table Extension
Simplify your workflow with a router table extension purpose-built for the MFT/3. The flush-fitting design enables you to use the large work surface of the Festool MFT/3 as router infeed/outfeed support, helping you maximize your workspace and productivity. Compatible with the most popular trim routers on the market.
JUST RELEASED! MFT/3 Extension Table
Expand your Festool MFT/3 work surface by 33%! This extension utilizes three precision machined brackets that quickly lock into the MFT/3 perimeter extrusions to provide a rigid, seamless extension of your worktop. The MDF top is CNC-machined and shares the same 20x96mm hole pattern as the MFT/3, ensuring compatibility with all of your workholding accessories.
JUST RELEASED! GRS-16 PE v2 Guide Rail Square for Festool, Milwaukee & Makita Track Saws
"Version 2" of our popular guide rail square now includes a fast attachment feature: simply insert the square at any point along the guide rail and clamp it in place—no need to slide it into the guide rail from one of the ends or remove hose deflectors, clamps, or other accessories occupying the guide rail T-slot.
JUST RELEASED! GRS-16 PE D Guide Rail Square for DeWalt Track Saws
The proven design of the GRS-16 guide rail square has now been adapted to fit the DeWalt track saw system! Like the original GRS-16 and GRS-16 PE squares, the GRS-16 PE D makes it lightning fast to achieve dead square cuts with your DeWalt plunge saw.
MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
GRS-16 Guide Rail Squares for Festool, Milwaukee, Makita & Triton Track Saws
Our patented designs are born square through precision CNC machining and an innovative self-aligning latch mechanism. Simply slide the square onto your guide rail and lock it into place. Five seconds to square!
Padded Storage Bags for Precision Tools
Whether in the shop or on the job site, a little insurance for your fine tools is always a good move. Check out our new padded storage bags for guide rails up to 55" in length, parallel guides, and precision triangles.
