RobJameson
- Apr 10, 2021
I am considering buying a TKS 80 table saw, and was looking over the user manual to learn about it. On page 31, it says:
SawStop technology is triggered
► Only switch on the TKS 80 EBS if the saw blade is not in contact with the workpiece, accessories or other objects.
► Only use accessories intended for the TKS 80 EBS.
I'm confused about that. I understand that SawStop can be triggered if anything that isn't supposed to be cut (like a finger or a sausage) comes into contact with the blade.
But I am accustomed to using after-market accessory fences and building my own, from wood, aluminium, or steel. If there is some way in which SawStop can be triggered by an accessory that is not touching the blade - entailing a fairly expensive replacement cartridge and blade - then that is going to be a problem. And I assume that no table saw accessories would ever touch the blade in normal use.
Can anyone shed any light on this?
