I'm building some closet cabinets for the master bedroom. Got the carcasses assembled, LED's installed, and decided to load up one to see how it looked. I'm using the oval Hafele word robe euro rods that have the 32mm ends (Which fit nicely into the LR32 holes I drilled all down the side of all the cabinets) and the cabinet's are about 42-inches wide. Loaded up the first one about half full and the rod drooped about 3/8-inch in the middle...well crap. Looking at it, I'm not at all shocked and I'm more disappointed that I didn't see this coming. Such a thin aluminum extrusion can't handle the weight of that much clothing.
So the question - what do you guys use? I know I've seen closet cabinets that had to be about the same width. Ideally I can take advantage of the 32mm holes but I clearly need something a little heavier duty. On the upper rod I can use an adjustable but only because the upper rod happens to be 3" from the top which is perfect for the supports. Rods that end up mid-height won't be supportable using the same method.
An obviously solution would be to narrow up the cabinets to about 24 inches per however that would increase the sides/material by nearly double and since I thought the fab was done, I'd like to see if there's another solution (heavier round rod or something) that doesn't require more fab , more materials, or a different design (more machine work).
Thanks!
Thanks!
