smorgasbord
- Jan 7, 2022
I've had a Bosch "glider" SCMS (the 12" one) for a while. It's "serviceable" but not really accurate.
First up is crabbing. I think a lot of sliding saws have this problem. It's where the blade isn't perfectly parallel to the slide. I don't think it's adjustable on most saws (is it on the Kapex?), but would love to hear about saws where it could be adjusted. I think many of the old radial arm saws could be adjusted, fwiw.
The crabbing problem means that if you adjust your saw for a full width cut at 90º to be accurate, a narrow stock cut that uses the chopping motion won't be accurate. I suppose the fix is to always use the sliding action? Thoughts on that?
Second is flex. I didn't use to think flex was a problem as I always take the same stance and use the same motion. But I started noticing that my zero clearance insert got chewed up, even when I never adjusted the bevel from 90º. That shouldn't happen, right? The only thing I can think of is that I'm pulling the thing to the left or right differently and so the blade tracks in a different position, thus chewing up the insert.
And while I'm at it, what's with zero clearance inserts on a SCMS? On any saw with the blade on top - think tracksaws for instance - you don't get tear out at the bottom, so why would you on a SCMS? On tablesaws with the blade on bottom I don't get tear out on the top (at least if it's aligned properly so the rear teeth don't slightly rub on either side of the kerf pulling those fibers up). The only zero clearance to reduce tear out that can properly be done on a SCMS/chop saw is the rear fence. And no-one makes a SCMS with a true zero clearance fence - you have to jerry rig that up yourself. I did that with a big block (seehttps://www.festoolownersgroup.com/...stalled-colliflower-cube/msg707477/#msg707477 ) that's worked out really well since those blocks are easily/cheaply built.
If you want to reduce tear out on the face of a board being cut with a SCMS, I think you have to do a partial depth scoring cut, pulling the saw out towards you if you can do that safely (which may mean having some kind of depth limiter). Perhaps Festool should adopt their TSV-60 scoring blade assembly to fit the Kapex?
And, more on tear-out, does the saw behave differently for sliding action versus chopping action in terms of tear-out? I haven't thought through the geometry that carefully. Yet.
Third is the angle setting. I really like how the Kapex has that knob for dialing in the bevel angle, but not sure how I'd setup a gauge to align it since I suspect the bevel angle markings (stops?) aren't accurate enough. Let me know if I'm wrong there - I'm talking 1/10º accuracy. As for miter angles, while you can adjust any saw to cut an accurate 90º (modulo crabbing), the stops elsewhere may not be accurate. I've read some "fixes" involving filing and feeler gauge shims, hmmm.
I'm kind of tempted to sell my Bosch and get an old DeWalt radial arm saw instead. I wouldn't use it for ripping or any of the other weird things once promoted for these says, just use it as a more accurate SCMS. I see there are still new ones made (The Original Saw Company), but they're quite expensive, too. The width capacity of 12" radial arm saws beats any SCMS, too.
