builderbob said:
Bona traffic is good as is Street Shoe...both are latex & are a A + B epoxy mix and are used quite often in this area!
Bob
Traffic would be about as equal to street shoe.
Some floor guys around here have switched to bona because they were getting streaks and other problems with street shoe's latest formula.
As for dura seal is that a oil base product?
All oil base varnish/poly get worst every year because the gov. is forcing then to lower the voc every year,
The oil base stuff that was great years ago is now cr@p.
Stuff like fabulon used to be great stuff years ago but not now.
Even the Moisture cure stuff that was a extremely tough finish years ago is not that tough anymore. I don't think you can get that Moisture cure in Canada anymore witch is a good thing as it was extremely bad health wise.
In Canada it might be the last year that we are able to buy oil base varnish/poly.
Stuff like like Bona Traffic & Street shoe is a stronger finish then the oil base of now days.
Go with water base'
The voc are a lot less lower
More durable then the oil base stuff that's available today.
wont yellow
dries fast so you can put 3-4 coats in a day
no toxic fumes.
2 coats of bona sealer and 2 coats of traffic will do the job. If you dont want to use a 2 part product then use bona mega instead of the traffic.
I have been staining and varnishing staircases and doing lacquer spraying for 20+ years and switched to the water base stuff this year and I'm glad I did.
