online421
- Mar 7, 2016
I have owned a DF700 for more than 4 years now, I use them in my semi commercial shop.
I have been wanting to get another Domino because the constant change of the bit is getting too much.
the question is, Should I be getting the DF500? or stick with the DF700? I like the ergonomics of the DF700. although its heavier but I find it easier to use.
I mostly use 8mm cutter to 14mm cutter. for the times I need smaller cutter I use the Seneca adaptor, its not perfect but it will do.
I wonder what will I miss out if I go with either way?
Thanks!
Thanks!
