stvrowe
- Jan 27, 2007
I tried using the RTS self centering guide for the first time today on the Domino XL. I went through the calibration procedure and have run out of adjustment. It will not even get all the way to the center mark on the base. The best I can get it is a 0.88 mm offset so I need another 0.44 mm of adjustment. I have checked the window center of the Domino and it is dead on. Using the Festool Trim Stop, I can't even get my fingernail to catch on the joint.
Here are some pictures;
Top is trim stop, bottom is SCG
[attachimg=#]
Shows 0.88 mm offset using SCG
[attachimg=#]
Shows perfect joint using Trim Stop adjusted to window markings
[attachimg=#]
Need to move the SCG left but it is hard up against the mounting screws. (BTW - the centering plates are not causing this problem)
[attachimg=#]
I need to move the SCG more to the left to make it centered. It looks like I could loosen the cable clamps to and move the mechanism to restore the adjustment but, I shouldn't have to do this on a brand new accessory and this procedure isn't discussed in the owners manual. I had great hopes for this accessory but, unless this issue gets resolved, it is going back.
Any help would be appreciated.
[attachimg=#]
[attachimg=#]
[attachimg=#]
[attachimg=#]
