demographic said:
Was someone else using the cables/splitter feeding that saw as well?
I've noticed that if I'm using it and someone else uses a high drain item like a chopsaw off the same feed it really slows it down till they finish the cut.
Ideally I run my own extensions and don't let others use them. I can't use two tools at once so what ever I have connected doesn't affect the other tools.
I had that a few times earlier this year when we were using a 5kva trannie. Everyone seemed to think because it's 5kva, it could power everything at once. Mine would slow down so much (TS55/ midi combo) it was unusable. So if someone started a saw etc as i was about to cut, i would stop and let them do theres, then carry on.
I am now considering getting my own 5kva trannie and blanking the 16amp supplies off,
using the 32amp socket only. That way no one else can use it, as they rarely have 32amp leads. [big grin]
