So I'm building an MFT/Systainer cart. I purchased the 18mm/12mm domiplate because I am using 18mm Baltic Birch. The domiplate/Domino 500 bores a perfect Center mortise at 9mm (so it centers on the edge of the Baltic Birch Ply).. I need it centered because the spine" Which is a cut piece of plywood that goes right down the center of 2 cut pieces of cut-to-size Top/Bottom Baltic Birch forming an "I" beam - kind of. So I bore the mortises for the dominos in 4 locations for the plywood which will be the "spine" but when I remove the Domiplate to bore the mortise in the bottom part of the "eye beam" (so to speak) (there is two pieces of plywood that are parallel to each other - top and bottom and then a "spine" that runs down the center but now I have to bore mortises dead center in the bottom board BUT the domiplate has to be removed in order to register on the "spine" which I have now laid down on the bottom piece to be used to register to the mortise bore into the bottom piece. But the Domino 500 will only bore at 10mm which puts it off center. It must be in the center because there are partitions which have been cut to size and if the spine is off-center then the partitions on one side will be too long. Can anybody suggest a work-around for this problem?
