ear3
- Jul 24, 2014
Someone shared this method a couple of years ago on the FOG which I suddenly remembered earlier today because I'm doing a project where I'm Edge joining wider boards and so want to be sure that my cut is truly 90°. Very simply it just involves removing the cover and then using a digital angle gauge to check the blade relative to a trusted flat surface in this case my table saw bed.
Turns out it was off .3 degrees. Not a lot, but if I can get it to 90, why the heck not? Adjustment is made through the set screw at the front of the song. In my case it was a quarter turn at most. Now it's dead Plumb 90. Incidentally, this adjustment was not available on an earlier version of the TS 55 i owned and which was the source of a lot of complaints on the fog about getting it set to 90. They have since updated it as of 2 years ago to include a set screw.
My only question/concern is this: given that the adjustment is only made on one side of the saw is it an issue the front and back of the saw going out of alignment? Meaning as you're pressing down on the side during the cut would there be a chance of the back flexing down a bit because there's a little more space underneath it? I made a few Cuts in and it seems to be fine.
By the way, as you can see from the pictures at the end it's a good idea to occasionally clean out the blade housing.
