Shooting Plane FTW
ear3
New York, NY
It's not everyday that I need to use my shooting plane, but when I do, there's nothing else that can come through (short of a lifetime of apprentice craftsmanship that I do not have, or perhaps the Bridge City Tools Jointmaker pro, which I also do not have).
Had to recreate some handles for a designer that was installing a kitchen, and who needed exact replicas of the OEM handles in another size not provided by the cabinetmaker to match some other elements of the kitchen. Very basic design consisting of a 1" diameter half cylinder nested on two small, 19/32" square rectangular posts with a corresponding convex radius. The convexity had to be cut into the endgrain with a core box router bit, and since I was working off 3" wide boards, I didn't want to cut it all the way to the edge and lose stability of the workpiece (despite it being clamped to another board to stabilize as I ran it over the router table). So I cut the cover just a little shy of the edge, and then worked it with the shooting plane to the target size. Glue, screw, plug and voila.
Each time I have been inclined to get a shooting plane, I have found that my 40 year old Lion Miter Trimmer was up to the task. It is limited in width, so it will not do all that a shooting plane can do, but up to 6” wide at 90 degrees or about 3-1/2” wide at 45 degrees. Or any angle in between.
If you are primarily using narrow stock, an alternative. It can take cross grain slices thin enough to see through like tracing paper.
Mine is an original from Lion (now out of business due to the many knockoffs from offshore).
Infinity Tools makes a very nice version of it. Offered from many vendors under their own name, they might all be from the same offshore vendor.
I was gonna jokingly say “thought this was a power tools chat room?” 😜
But then saw you posted into ‘Hand Tools’, thusly paring away my joke. 🤐
Very nice use of the hand tool. Appreciate that tip.
