Shop flooded/vac went swimming
JascoJos
So my CT26 went in the drink for about 12 hrs. I’ve taken it all apart and dried it out. I’ve multimetered back to the motor and I have amps to it but still won’t run. I was wondering if the carbon set may be the issue. Not even sure what it does. I’m assuming the motor is still in good working order only cause I was able to save all my other tools. Any suggestions would be greatly appreciated. Also, how many volts (edit: previously wrote amps) should I be reading on the spade terminals that connect to the motor? Thanks a bunch.
You should be reading mains level, at least when set to full suction.
