Patrick Cox
- Apr 25, 2016
I am going to make a jig for ripping narrow stock with my TS55 and I have a question. I am typically working with 3 different materials...
1. 3/4" Plywood
2. 1x material (which I believe is slightly thicker than 3/4" once dimensioned.)
3. 1/2" plywood
I would say I will mainly use this jig for ripping 1x material but I am sure the need will arise for cutting narrow strips of plywood as well.
My plan is to glue a "fence" strip to the top of a roughly 4 foot board and then place the non cut edge of my rail against that fence and then cut the base of the jig down to the width of the rail. I can then add spacers between the rail and the fence with the board to be cut placed underneath the rail and butted up next to the base of the jig and I can then rip pieces down to the desired size (same size as the spacer.)
My initial thought was I would use the thickest material I would mainly cut and use that to build the jig. So I bought a piece of pine at home depot that I thought looked straight but it turned out to be twisted. So I think I will need to start over.
So my question is, if I build the jig using plywood, would that work ok for cutting boards that are slightly thicker than plywood like 1x material? If not, I guess I will need to spend a bit more money on dimensioned lumber as I don't have a jointer/planer. Below is a sketch of what I am planning. Please let me know if this does not make sense! Thanks!
1. 3/4" Plywood
3. 1/2" plywood
