dogutsukawu
- May 24, 2010
When ripping stock narrower than the width of the guide, the non-cut side of the guide tends to sag under the weight of the saw. Hence the practice of putting stock of the same thickness under the guide to support it and prevent sagging. In other words, we "shim" the guide. Not a big deal, but often a nuisance to get a shim of the right thickness.
Here's one solution to the shim problem.
[attachimg=#]
I wedged a super magnet in the upper T-slot of the guide. I cut a piece of PVC pipe to length, and epoxied a washer to the pipe. This shim attaches to the underside of the guide and stays there, thanks to the magnet.
[attachimg=#]
Although the guide is shimmed only at its midpoint instead of its entire span, it's enough to essentially eliminate sagging.
You can make a set of shim of varying sizes matched to the stocks you use, and label each with the corresponding stock thickness. They take very little space and you'll always have on hand a shim of the right size.
[attachimg=#]
[attachimg=#]
