Simple jig for cutting circles with the OF-1400
Enrico74
Hello,
I had to cut a circle and tried to figure out how I could do this with minimal effort.
I came up with a very simple DIY jig that attaches to the guide rail adaptor of the OF-1400.
I made it from a scrap piece of MDF (22mm thick).
[attachthumb=1]
[attachthumb=2]
[attachthumb=3]
[attachthumb=4]
I drilled two holes for the pivot point, one that accepts a 4mm screw and a smaller one for a nail.
Have a nice woodworking day !
Thomas
PS: As I was writing this article I found that woodgeek had a similar idea:
http://festoolownersgroup.com/index.php?topic=1410.msg13494#msg13494
I made a similar jig from aluminum.  The hole for the guide pin bolt in in the center but it doesn't really need to be.  And I used the fine adjuster screw from the guide rail adapter.  And I have two screws to lock the aluminum block down on the bars but you probably don't need that.  But it's nice to get it all locked down.  Photos here:
http://dan.pfeiffer.net/tools/festool_of1400_circle_cutter.htm
Dan Pfeiffer
