Simple solid table
Falch
And another one :)
This one was just going to be a simple design, The only thing i "had to implement" was "hidden" drawers on eah side of the table.
Again, this was also white oak, stained with walnut poly-x.
The table is 80x65x40 cm, and has a hidden brace between the "legs" centered between the drawers.
[attachimg=#]
[attachimg=#]
[attachimg=#]
So yeah...Cheers
Very nice!
Could you explain how you managed to keep the grain flowing from the leg to the top?
Did you build one long panel, then separated the legs from the top using a track saw set to 45 deg?
Sure! Well, you almost nailed it. The flow is not perfectly "flowing" but almost. Since the miter goes both ways (as in removing a 90degree angle from it), it was easier to just cut the panel up and miter it afterwards with the ts55. :)
