Terry S
- Mar 28, 2014
Goal: Move from softwood cabinets and trim work to projects using regional hardwoods.
The Kapex sale has finally moved me off the fence. I'm replacing an old radial arm saw (dust bomb #1) with a Kapex, & CT 36. As soon as I commission those I'll be adding a TS 55, MFT, rails, etc... to be able to precisely break down my sheet goods. This has always been my big show stopper, eg. done a lot of sawing with a circular saw (dust bomb # 2) and small table saw (dust bomb #3). Almost all of my work has been with various soft woods. I live in hardwood country and there's numerous mills within a 1/2 hr drive that have great deals on kiln dried & milled North East hardwoods. Once I get the Kapex and track saw dialed in I'm going to up grade my current router system (dust bomb #4) to a Kapex CMS system. OK the previous is a given to get to where I want to go. Where I don't have is experience in the Domino system. I'm pretty sure I'd like to move away from pocket screws on my face frames to tenons where appropriate and possible. It appears from my research that the Domino is the way to go. Assuming that my board thickness and end cuts are up to snuff:
1) Will the Domino 500 system give me nice neat joints on 3/4" hardwood face frame stiles with a minimum of fuss?
2) It looks like the Domino is an efficient system for assembling 3/4 BB frames and then attaching the 3/4 hardwood face frames?
3) If there is a slight board thickness difference in the face frame boards can I easily set up the Domino so the difference goes to the back side of the face frame board and then just sand or plane the proud board even? I"m trying to avoid or delay getting a thickness planer. I'm figuring on being careful in my stock selection at the mill. In a real pinch I can put my good blade on my portable table saw and trim down a board, my max limit on that would be around 4" but I'm sure I'd end up with saw marks on hardwood. Not forgiving like pine.
4) I'm thinking that the big change for me will be using the Domino system in my work flow instead of pocket screws. I'm going to start with some hardwood built in's in my closets and then move onto the bathroom and kitchen cabinets. Where I'm looking for reassurance is the investment in the Domino system for working with 3/4 in Maple and Cherry instead of pocket screws?
Thank's for any input, Terry S. (See ya at the JLC Live?)
