Hello All. I know there are very good machinists and metal workers here. I'm a glutton for punishment and recently picked up cast iron table saw table to use as my router wing extension. Table is big 20" x 27" and the holes i need to slot are on the sides. I managed to drill them out already but 3 holes need to be slotted to accommodate my table saw attachment points.
Here i need to slot it to the marker outline. So far i tried a drill bit and endmill. It works but very very slow process. There is a support rib on the other side of this hole which doesn't help
I also have dremel and carbide stone but haven't tried it. I don't have a die grinder, do have palm router but not sure its a good idea.
in the second picture i drilled out another hole and just need to connect them.
What is the easiest, safest and fast way of accomplishing this?
Thank you
Thank you
