Mike Goetzke
- Jul 12, 2008
My drive and sidewalks are in-between needing a single or two-stage snowblower. Many years ago I started with a Toro single stage then about 10 years later sold it and got a 2-stage. After couple years the 2-stage seemed to big so sold it and got a top of line Toro single stage again. It worked great except for the large piles the snow plow leaves at the end of the driveway. Next two seasons ago I see a new 2-stage in the Lowe's clearance for 1/2 price and couldn't resist (guy said it had a bad tire and had to be replaced and couldn't be sold as new - he showed me the repair papers). I miss being able to easily get a snowblower in the backyard for the sidewalks and patio so I have had the itch to get a used single stage. I'm retired and sort of looking for an inexpensive one that may need work. Well I found one yesterday before the snowblower flip guys did. It's a Toro 621 QZE 4-stroke. Starts right up but smokes a bit and surges/hunts with the choke removed. I'm 98% sure it's the carb running rich because there is the smell of fuel in the oil too. From what I have read this is not uncommon.
Toro made it difficult to remove/replace the carb (many panels to remove, fuel tank, electric start...) but I have time to tinker. Here is my plan but wondering others that may have had Toro carb issues can shed some experience:
You can get to the carb float cup without removing anything. I was thinking of first removing the float cup so I could get at the main jet and emulsion tube and clean them well. I saw in a YT video that you can also get at the idle screw and orifice to clean them too. Then I would flush the fuel tank and replace the engine oil. If this didn't work I would continue below.
If I end up needing to remove the carb I see three options:
1) thoroughly clean the carb (I have a sonic cleaner I use for my LP's that I saw a few people use to clean these small carbs with Simple Green & water).
2) purchase a $20-$25 carb on the internet.
3) purchase a Toro carb $54.
This is where I need help deciding. I could do (1) but not sure all the gaskets/seals could be reused. Plus there may be a chance it still needs a new carb. I did see a YT guy that claims he has repaired 100's of snowblowers and this cleaning works 95% of the time. On the other hand if I take it all apart the other side of my brain says to get the new Toro replacement. Guess I could try (1) and take it apart again for a new replacement if needed - second time always goes quicker.
Thanks - Mike
Thanks - Mike
