Lucky Dave
- Oct 3, 2007
2 barely used Veritas 6 1/2 in Wonderdogs
$ 70
davelame@gmail.com
"At 6 1/2" long, the versatile Wonder Dog clamp can be used anywhere you can drill a 3/4" hole. It makes it easy to clamp curved work and irregular shapes. Since the dog head has two screw holes, any shape of tip can be cut with a scroll saw and quickly attached for specialized work, giving good control without marring work.
Using a Wonder Dog in combination with a standard round bench dog, you can make a clamp of any length by drilling 3/4" holes in a 2 × 4, 2 × 6, etc. Two pieces of plywood with 2 × 4s between them for spacing can be drilled in a pattern to provide clamping for curved work and an infinite variety of other shapes.
At the lowest projection, only 5/8" of the dog head is above the bench. The swivel handle lets you apply ample clamping pressure in any position. The dog is drilled and tapped at a 3° angle to ensure that work is held tight to the bench." Veritas
$ 70
davelame@gmail.com
