nickao
- Feb 24, 2008
289.00 & FREE Shipping and if you do not like them I will return 100% of your money upon getting them back.
FREE ship to the continental 48 only.
One battery and one charger on eBay is going for 115.00 and more! That leaves less than 60.00 each for each tool and free ship. ONE battery only in the set. Even on eBay you can not get each of these tools for less than 60.00, even without the battery. This was NOT purchased as a kit, the tools, charger and battery were purchased separately so I spent way more than 300.00 on everything. I am not sure you can get quite this exact combination all at once at the big box store.
Everything but the Circular saw can also take the Ridgid 18 V batteries.
1- 24V Li-Ion Battery 1- Battery Charger
Features
Ideal balance of power to weight perfect for professional contractors
Outperforms 18-volt Ni-Cad with a 3.0 Ah high capacity lithium-ion battery
Runs up to 160% longer than 18-volt Ni-Cad and weighs 7 percent less
Fade-free power runs at full power to the end of the charge
Ex-cell Diagnostics self-monitoring battery extends cycle life (recharges) up to four times a Ni-Cad battery
1 - R883 Dual Voltage Jig Saw
Features
Works with both 24 volt and 18 volt battery systems
Variable speed switch ? for easier speed control and precise starts
Dual bevel cutting ? base allows both right and left bevel cutting
Tool free blade clamp ? makes blade changes faster and easier
Tool free shoe adjustment ? allows adjustment of shoe with one hand
Specifications
Volts: 18 V NiCd or 24 V Li-Ion
Stroke: 1 in.
No Load Speed: 2200 SPM @24 V
1 - R888 Dual Voltage Hand Planer - The brand new dust bag for this is included.
Features
Belt drive ? quieter and easier to maintain
0 ? 1/16 in. depth adjustment ? micro-settings for finer depth control
Rabbeting capability ? make rabbet cuts up to 1/2 in. depth
Automatic rear stand ? protects surfaces from accidental planer contact
Replaceable spiral cut planing blades ? provide a smoother, faster, easier cut that doesn?t ?stutter or dig? into the wood
Specifications
No Load Speed 13000 r/min. @ 24 V
1 - R855 CIRCULAR SAW
Features
Volts 24
Arbor Size 5/8?
Blade Size 6 1/2?
Speed 3900 RPM (no load speed)
Cutting Depth 2-1/8? @ 0? 1-5/8? @ 51?
I purchased these tools and they just sat and I never used them except to test them.
The jig is missing the plastic shield, I misplaced it. The manuals are missing also and no original packaging. The tools are perfect. 30 Day money Back Guarantee.
1 - Jig, 1- Planer, 1- Circular Saw, 1 - 24V Battery, 1 - Battery Charger
Features
Features
Specifications
Stroke: 1 in.
Features
Specifications
Features
Volts 24
Arbor Size 5/8?
Blade Size 6 1/2?
