SOLD: Fein Multi-Master Oscillating Tool for sale
16paws
Selling a Fein Multi-Master Oscillating Tool in case with below attachments.  Used once!  New at The Tool Nut $350, asking $275. Buyer pays shipping.
Features
The high performance, universal system for interior construction and renovation with comprehensive accessories for unrivaled versatility.
Self-supporting motor with vibration decoupling for outstanding vibration and noise reduction.
Very powerful 350 Watt FEIN high-performance motor for optimal cutting speeds and maximum work progress.
Highest quality and stability thanks to metal gear case and consistent use of ball or needle bearings.
Convenient QuickIN rapid-clamping system
Electronic speed control with tacho generator for constant speed, even under load.
Integrated interface for mounting additional system accessories.
Softgrip zone provides optimal handling.
StarlockPlus tool mount with outstanding torque transfer, fits all Starlock, StarlockPlus and StarlockMax accessories.
Wide selection of accessories available for all applications.
Includes:
(1) FEIN MultiMaster FMM 350 QSL
(1) backing pad
(3) of each sanding sheet (grits 60, 80, 120, 180)
(1) perforated backing pad
(3) of each sanding sheet (grits 60, 80, 120, 180), perforated
(1) sanding disc 4-1/2 in dia. perforated
(6) sanding sheets 4-1/2 in perforated (2 each of grits 60, 80, 180)
(1) dust extraction assembly
(1) rigid scraper blade
(1) E-Cut Long-Life saw blade 1-3/8 in (35 mm) (type 160)
(1) Universal E-Cut saw blade 1-3/4 in (44 mm) (type 152)
(1) E-Cut Long-Life saw blade 2-9/16 in (65 mm) (type 161)
(1) HSS segment saw blade
(1) carbide segment saw blade
(1) carbide rasp (triangular)
(1) tool case
