SOLD: Festool 2015 LE Wood Centrotec Systainer - 500875 - $400 shipped
jeh
The content list and first two photos were taken from a FOG post. I have not removed anything from the set, nor used any of the bits. Bought it because I thought I needed it, but in reality don't. Plus there was the feeling of getting something that was NAINA. I make no guarantees that this list is perfect, but my pictures show that it is at least 99.99% correct. Also, there are multiples of each bit so they could last you a life time. $10 extra if shipped west of the Mississippi.
In the photos you'll notice some blank areas on the bottom. Those are for your stuff (screws, inserts, drywall anchors, other bits, etc). It's not shown in the photos, but there is a cardboard cover showing things such as that. The post referenced at the top of the listing mentions this somewhere.
Contents:
CENTROTEC DRIVE screwdriver handle
CENTROTEC pricking awl (new, not in standard product ranqe!)
drill adapter
centrotec adaptor
deburring countersink QLS D5-15 CE
bit extension
BV 150 CE
standard bit holder BH 60 CE
hook driver HD D18 CE
tool chuck WH-CE CENTROTEC
20-piece drill bit case HSS D 3-10 CE/10
wood drill with centring tip 4 mm
wood drill with centring tip 5 mm
wood drill with centring tip 6 mm
wood drill with centring tip 8 mm
wood drill with centring tip 10 mm
ratchet with Festool design
socket SN5.0
socket SN5.5
socket SN6.0
socket SN8.0
socket SN10.0
socket SN11.0
socket SN13.0
extension
ball joint
l/4" Centrotec adapter
1/4" socket bit holder
Pozidriv bit PZ1
bit PZ2
bit PZ3
Phillips bit PH1
Phillips bit PH2
Phillips bit PH3
Torx bit TX 10
Torx bit TX 15
Torx bit TX 20
Torx bit TX 25
Torx bit TX 30
Long bit 55 mm PZ1
Long bit 55 mm PZ2
Long bit 55 mm PZ3
Long bit 55 mm TX15
Long bit 55 mm TX20
Long bit 55 mm TX25
Long Bit 55 TX30
Long bit 55mm PH1
Long bit 55mm PH2
Long bit 55 mm PH3
Hexagon socket bits 2 mm
Hexagon socket bits 2.5 mm
Hexagon socket bits 3 mm
Hexagon socket bits 4 mm
Hexagon socket bits 5mm
Hexagon socket bits 6mm
