WestMan_Canada
- May 9, 2020
ebay item Item ID: 293716886109https://www.ebay.com/itm/293716886109
Appears to be near-new condition.
All bags are sealed except for 5mm from which it appears not more than 12 Dominos have been removed.
This item carries Festool label DS 4/5/6/8/10 1255 BU and PN 497704
However this set does NOT include any cutter bits.
It is packed in the original Systainer 2 case with labelled, wood divided compartments for each size Domino.
Therefore based on how the bags are labelled the assorment contains the following beech wood tenons
Qty 450 4mm × 20mm
Qty 190 6mm × 40mm
Qty 130 8mm × 40mm
Qty 100 8mm × 50mm
Qty 85 10mm × 50mm
Approx Qty 280 5mm × 30mm
Qty 450 4mm × 20mm
Qty 190 6mm × 40mm
Qty 130 8mm × 40mm
Qty 100 8mm × 50mm
Qty 85 10mm × 50mm
