Festool Precisio CS 50 EB Table Saw 240V (Model 493752) UK
Comes with:
Basically it’s the “set” version but without the rear extension table as I use the MFT for that.
I bought this in October 2017 and it has had light DIY use only since that time, including 2 years in storage. In very good condition, but a couple of points to note:
I am selling because I now have a larger more permanent place to work from so I am upgrading to a larger cast iron table saw.
Collection preferred from Malvern, Worcestershire, but happy to discuss alternative options.
Looking for £850 ono.
Also pictured is the table saw on a birch plywood mobile stand which can be included if needed.
Comes with:
- Sliding Table ST
- Extension Table VB for CS50 (side)
- Stopper LA-CS50 Fence
- Saw balde holder
- Universal saw blade
- Rip saw blade
- Dust extraction set
- Benchdogs Angle Stop Adapter Plate for usign different fences on the angle stop such as Benchdogs or Incra
- I have always had to shim the extension table at the back to make it square to the main saw table. It’s minor but only ever a potential issue if you use the rip fence for wider pieces but with the sliding table being so good I rarely need to do this.
- The extension table has a very small dent in the top (see picture) but this does not affect use at all.
- I don’t have the two rubber screw end stops for the sliding table which stop it sliding off the track, although I have never had this issue.
