SOLD - Hilti 267E Circular Saw
Mike Goetzke
Like new $300+shipping. Used in my hobby shop on a track saw system - also includes case.
The WSC 267 is a great saw in it’s own right, and a great complement to the Festool track saws as part of a larger carpentry system.
As a standalone saw, this Hilti saw is uniquely well suited to residential carpentry work. With 1500 watts of available power, paired with an efficient Hypoid gearing system, the WSC 267 has plenty of torque to rip through tough timbers like LVL beams.
This saw accepts standard 7.25”, 5/8” arbor circular saw blades.
The rear dust port is very efficient at directing chips (there is an air channel to the front cutting point of the blade), and is fully compatible with Festool, Fein, and Hilti dust extractors, making for a much cleaner work environment.
Variable speed allows you to adjust the blade speed to the material you are cutting, whether that be steel, concrete, wood, plastics, aluminum, etc.....
Front and rear bevel locking levers make for a very stable platform when performing bevel cuts.
A handy depth stop makes plunge cutting to a specific depth an easy operation.
Finally, a groove in the base makes this saw compatible with the common Festool guide tracks, as well as the Hilti and Makita tracks. This allows a user to utilize their Festool saws for fine carpentry, and, using the same tracks, use the Hilti saw for general and rough carpentry.
Mike
