SOLD - Short Kapex DE Hose
RKA
Sold...sold...sold!
I have a 9-10 ft length of 36mm non-antistatic hose available for $25 shipped (CONUS).  You can trim it to your desired length.  5-6 ft should be about right.
This is the bosch hose, but it's identical in build/dimension to the Festool non-AS hose.  You will need to order at least the Festool 36mm tool end connector for the hose (487721) which is $23.  Optionally you can order the rotating vacuum end connector (452894) for $25 or I can include the Bosch vacuum end connector for no charge (fits fine in my Mini vac).  The Bosch connector doesn't rotate and the it only pushes onto the hose, so it doesn't have the solid threaded attachment like the Festool hose ends.
Raj
