SOLD - UK - Festool Domino DF700 to df500 Seneca adapter & Shim
jmac80
SOLD
Hello
Selling my seneca adapter & shim for the XL DF 700 domino.
The RTS-500 Cutter Adapter is a precision machined, hardened steel component that allows mounting any of the Festool Domino DF 500 cutters to the Festool Domino XL DF 700.  This enables the DF 700 to cut smaller mortises that previously could only be done with the DF 500. Any of the standard Domino Cutter bits (4mm/5mm/6mm/8mm/10mm) will work with this adapter.
The Seneca Woodworking Domi-Shim is a machined aluminum shim that extends the lower travel limit of the Domino XL fence so that smaller offsets can be used.  This enables centering on smaller materials such as 1/2" or 3/4" plywood.
SOLD
Many Thanks
