HowardH
- Jan 23, 2007
Sometimes projects go exactly as planned, or close enough and then there are ones like I'm building now. My son got a pair of JBL monitors to go with his Christmas present, a Yamaha MOXF-8 keyboard. Rather than they sit on the floor, I decided to build a pair of pedestal stands. Man, did things go wrong from there. I thought it would be best to create a pedestal from plywood, about 4" square and miter the corners so the plies wouldn't show. Sounded good on paper. However, I discovered with a right tilt saw (hammer K3) that in order to get the miters in the proper orientation after the first 45 miter, I had to flip the board around where the miter was laying flat on the table. Turns out this creates another problem because the mitered edge slips under the fence since the fence sits up a mm or so off the table so it won't drag. Turns out none of the pieces were exactly the same size.
grrrrrrr. I dominoed them together and they are bit out of square so they are simply not acceptable. There's also some thing wrong with the set up of the crosscut fence. It must be just a shade off as I can't get it to measure out perfectly, or close to it, using the 5 cut system. After working most of the day trying to get it right, I said forget it and I'm going to start over. The bases turned out ok so I can use them. I think I'm going to create a sub fence that will be clamped to the Hammer fence that will ride flat on the table so that should prevent the miters from submarining under the fence. It's either that or just butt joint them using dominos since they will painted black. Who knows, I'll sleep on it and maybe wake up with a creative idea to make it work! Tell us about your project that went south right off the bat. I'm sure everyone has a project that you can laugh about now but not at the time.
