Some things I've made lately.
rjwz28
Hi everyone.  This is what I’ve been working on this past few months.
First, this is a clock I made for Christmas gifts this year.  It is made from sapele and mango.  The Asian character says long life.  It was lasered out of wood and I sprayed it gloss black.  Thanks to Jeff Belany at lakesuperiorlaser.com for doing the laser work for me at a very reasonable price.
2nd is a jig made for my palm router.  I made this to do inlays and banding work.  It has an adjustable fence so I can put banding on the edges of some projects.  I attached a tiny maglite so I can see what I am doing.  The fence is removable so I can also do some free hand work.
3rd is a stand alone box joint jig with a router mounted permanently.  It was in one of the woodworking magazines.  I added the box with the plexiglass top and a hole on the rear to hook up to my vac.
Last are clamps I use on my drilled work top.  I had them made by a friend who’s a machinist.  The other clamps are DeWalt clamps that are made for their track saw.  I modified them so I can use it both for holding down the track and also I can use it on my work top with the holes.  From the factory they didn’t fit in the holes so I cut off the back part that sticks out, welded the leg on and then ground a curve on the back and also ground away the welded part that was blocking it from going into the track.  So now I can use it both for above the work piece clamping and for holding the track when I use my DeWalt track saw.  Not bad for thirty something bucks for both of them.
Thanks for looking.
Aloha and Happy Holidays to all,
Rob
I love the clock!  I am assuming that the lighter wood is the mango.
I have the same laminate trimmer.  Did you use the single mounting hole that holds the bases for mounting to your plexiglass jig?  Mine is not close to me but I think that it has ribs on the back also.  Did you do something special to accommodate them?
Thanks Peter.  Yes I used the one large knob on the rear to mount the router.  No modifications to the router that I recall.  I forgot to take pics of the rear.
