Sortainer Sys 4 Bins
cpw
New York State
I purchased a Sortainer Sys 4, with the intention of using it for screws and other hardware.
http://festoolusa.com/power-tool-accessories/storage-systems/sortainers/sortainer-sys-4-200119
There is a container set:
http://festoolusa.com/power-tool-ac...tems/application-inserts/container-set-201124
Is it possible to purchase the foam blocks and the center dividers from the container set without the bins?
But I would prefer to use larger bins rather than the small bins that come with this set.  Lee Valley sells Tanos bins that fit the Sys Storage, and the medium and small are the same as the ones in the container insert set (I've got a few and they fit perfectly).  They also have a large bin that is equal to 3 of the medium bins; which seems like it would be useful for my application.  Rather than buying the container set, I would prefer assemble the set of bins that will actually make sense for what I'm organizing; but it would be convenient to be able to divide the center compartment as well.
Anyone have part numbers or links for these components?
Thanks,
Charles
I can't find the blocks or dividers listed separately.
Bin #s are .......
      Large 500068
      Medium 500067
      Small 500066
  Filler blocks should be easy to make if you don't really need the dividers.
As far as I know, the foam blocks and dividers are not available separately at this time.
Found the numbers on EKAT Germany.
- Center dividers are #10018359.
- Long dividers are #10017104.
Foam is not listed, easily make it yourself.
