I’ve become quite a fan of Centrotec; it has a couple of advantages that are not so immediately obvious - compactness and lightness, I find the CSX a delight to use with the Centrotec chuck - and the bit being held and driven by the output shaft of the motor rather than clamped in the jaws of a regular chuck.
I, too, find the lack of small sizes a disappointment; even just 2 and 2.5mm would be welcome.
As for the more general lack of bits mentioned above, I think this is a matter of Festool’s website than them not being made. All the regular-length brad-point wood bits seems to available individually - albeit only in whole-millimetre sizes 3-10 (?) - although the lovely and very useful stubby ones I have only seen as a set (3-8).
I probably have more use for the HSS bits; again they start at 3mm (and again that’s an annoyance) but I’ve seen them then in half-millimetre sizes up to, I think, 7 or 8mm, and then 9 and 10.
As for the cost… whilst the HSS are perhaps not the absolute best (or by any means most expensive) bits I’ve seen they are very good and may be somewhat better value than they first appear: with each one, you get the Centrotec holder and three replaceable bits. You can get packs of extra bits without the holder. (The bits have a little flat ground on the shank to bear the locking setscrew. You could perhaps get away with any other bit and grind your own flat, but I’ve not tried that).
In addition to Snappy (mentioned above), Axminster carry a number of Fisch’s Centrotec-compatible bits as well as their own branded augers, forstners and hinge (centering) bits - also fitting Centrotec as well as the more common quick-fit format . I’ve seen others say that Axminster have their export sales well-sorted, so that might be an option. I note that FFX seem to carry a fuller range of Festool’s own bits than many others - I’m sure others may have them too, I just happened to notice theirs.
Sorry - that was bit long-winded…
I’ve always assumed that Festool didn’t actually manufacture their own drill bits (I mean, why on earth would they bother with such a specialist process?). I noted that some of mine bore the legend ‘Made in Austria’ on the packaging, so I wondered if they might be Fisch or Alpen; anybody know?
