RALPH WERNETT
- Aug 26, 2014
My thoughts on using space balls spacers. They recommend using 2 each on all four sides, my grove is 3/8 x 1/4 and they recommend allowing 3/16 + per side, which doesn't leave a lot of meat on the bone... My thoughts would be to not use the space balls on the sides and just allow the normal space 1/8 +/- per side and just use the Space balls on the top and bottom with 3/16 allowance, knowing there isn't any movement on the top and bottom to speak of, but it would serve the purpose of keeping the panel from any rattles. I would make the panels as if I wasn't using the spacers and then just trim the top and bottom for their clearance so the reveal is the same on all four sides.
So if any has done this or have other thoughts on this - I'm open to someone that has been there and done it.
