Squaring a cutting board
Ghoffman88
I’m making and end grain cutting board and after  the glue up and flattening none of the 4 sides are square/parallel. I have a TS55 with parallel guides but no table saw. What is the best way to get the first edge square?
Second question, the cutting board is about 1 3/4 thick and it seems like it is really hogging down the saw. The blade is relatively new. Any suggestions on how to not make the saw was to so hard?
Greg
You'll need the 12 tooth panther blade for cutting with the grain and the 28t blade for crosscutting. The included 48t blade has too many teeth and won't clear the chips fast enough. The Panther balde should give you an acceptable cut in one pass with the grain.
1 3/4" hardwood is pushing the limit of the saw and you might need to cut in two or even three passes to avoid burning.  Cut a tiny bit oversize and then sand to your finished dimension.
You might also consider picking up a hand plane to prep or clean up the edges.  A No.5 or larger would be good.
A 12 tooth blade will slice right through it.
As for squaring it up:
1. Position the guide rail to make a straight cut at one long side of the board.
2. Make the cut.
3. Turn the board around and position the guide rail with the same offset from the edge you just cut. I'd use a rule with a stop to do that.
4. Make another cut. Now you have a board with 2 parallel long sides.
5. Using the same edge, make a square cut on the right and left side of your board on the miter saw.
6. Profit!
I hope it makes sense.
