STM 1800 as sawstop outfeed table
DIY WoodWerx
Anyone use the STM 1800 with a top on it as outfeed for a sawstop PCS table saw?  Does the STM height adjustability work out for the sawstop?
I don't see why it wouldn't.  The SawStop is at 34", I think the max height on the STM1800 is 35 and change, but adjustable down to 27 and change in 2" increments.
Dropping it one step would take you to 33 and change, so then just figure out if a 1/2" or 3/4" sheet would work better for the height you want.  If it's an 1/8th low, it probably wouldn't be the end of the world.
you always make a large shim to level the 1800 to the height of yer table saw. I like mine just a tad lower then the outfeed of my TS. The bc I use a ts75 in my CMS as my only table saw, the 1800 is compatable with it
