jonny round boy said:
David,
Aren't Li-Po batteries completely different to Li-Ion?
Johnny,
I was waiting for someone to ask that question (and its a great question). let me explain what little I know. Lithium in its raw state is combustible at atmosphere- not very good in our case. BUT, it can be made to release energy. Which is good in our case. SO, we create a compound to mix the lithium with to create a stable, rechargeable matter that can release and re-store energy for continual use.
The most common forms (at present) of compositions that are being mixed with Lithium to create a rechargeable energy state are phosphorous, iron, cobalt and sodium (though there are others). Lithium-ion is generic term to refer to a lithium based battery (in this case) with a cathode (or part B mixture) of another substance that can be changed at a molecular level (rechargeable).
I may be wrong, but I believe when I was at Festool training last fall in Indiana, I was told it was a Lithium Cobalt Oxide, but I could be mistaken.
Either way, they all will exhibit, more or less, the same tendencies and behave the same,
to the extent of our concerns with cordless drills. Some of the finer points, without digressing too much, is whether a manufacturer uses, Lithium Phosphate verse Lithium Cobalt refer to capacity of runtime verse number of times battery can be recharged, both with their pros/cons depending upon the n-users' needs. This is what causes so much confusion and disappointment with consumers today. They don't know what kind of Li-ion battery they are purchasing with their tool, and may not be best suited for
their specific needs.
Apples to apples the following general principle can be applied:
Lithium Phospate gives less runtime and more life cycles ( lower Mah capacity)
Lithium Cobalt gives more runtime and less life cycles (higher Mah capacity)
Again, apples to apples
Hope this helps a bit.
David
p.s. there is older technology that is also referred to as Lithium-ion that was the pre-cursor to the lithium-ion (Li-Po) batteries of today. Many times the characteristics of those batteries are swapped with this newer generation of lithium batteries which adds to the confusion. But again, in general the rechargeable lithium based batteries out in the tool market today will all exhibit the same preferences in regard to peak, nominal, and LVC voltages.
