Striebig AG takes over Otto Martin Maschinenbau GmbH & Co. KG
Hi!
The Martin family apparently sold to Striebig. Haven’t found an article on this in English language yet, so this will have to do for now:
Kind regards,
Olli
For anyone else that wants to know what a Vertical Plate Saw is...this thing weighs 2600#.
I know we’re having some fun here, but actually these vertical panel saws are very, very comfortable and fairly easy to use/ achieve precise results with. And with the right accessories, a single person can easily handle full sheets. https://www.kaiserkraft.de/transpor...n/plattenkarre/tragfaehigkeit-300-kg/p/M7540/
It’s a common sight here, every big box store offering cutting services/ cut to measure sheet goods, counter tops, (…) has one of these. Obviously make/model varies. The better big box stores have already expanded those services beyond just cutting. They will route/mortise for counter top joints, edge band, (…), as well. My favorite big box store has almost a complete wood shop in the back and actually employs trained joiners for the corresponding department.
Kind regards,
Oliver
  • Like
Reactions: P_K
For “premium class” shouldn’t the robot that loads panels onto the rig be included?
You'd move up to a beam saw at that point. The tricky thing is actually getting sized melamine panels off of a vertical saw without chipping them.
You'd actually want one of these if you're working alone at the vertical saw for an extended period. Gets tiresome lifting sheet goods.
