The following recommendations by current owners could help new owners to choose the correct abrasive discs for their specific applications. I have extracted them from this forum by using RAS and Saphir as keywords in the search function, therefore, this post does not claim to be inclusive. I would appreciate more contributions.
“When I'm scribing crown moulding or hardwoods I'll use 80 or 100 grit because the 24 and 36 grit is big and leaves a rough edge.”
“When I used the RAS and 80 grit Rubin, since I haven't ordered any Saphir and such, it took the paint off fast and still left the Rubin fairly clean.”
“I use my RAS up to 80 grit Rubin for exterior preparation.”
“I am not an expert here, but I have seen posts on this forum stating that the RAS removes material VERY quickly, and using paper below 80 is just too aggressive.”
“On average, I'd say, start cautiously with Saphir 50 and if that doesn't work you can decide to go to a lower or higher grit, depending on what you want. For most jobs related to paint removal, 50 grit will work fine. If you want to shape wood, you can go even lower. If you think you need a higher grit for less agressive sanding, get 80, but if you think you need to go even higher, get another sander like the Rotex or the ETS 150.”
“Saphir 50 is faster than Rubin 40, but it will leave a rougher surface which needs to be sanded further to smoothen it. I mostly use Saphir 50 or 80 with the RAS but always sand after it with the Rotex 150 in random orbit mode using 80 and/or 120.”
“I have a customer that is stripping a house using a RAS and Saphir. He seems quite happy. So happy, in fact, that he has bought more Saphir... He's been using 36 & 50. My understanding is that he's also following up with the ETS 150 using 60 & 80 Granat.”
“A big problem with grits below 60 is they scratch the underlaying wood more, and you'll have to do more sanding with a higher grit to remove those scratches again.”
“I prefer to not go lower than 60 grit, but if I must, I use Saphir 50 on the Rotex 150 or RAS 115.”
"Saphir 50 scratches a bit less than 40 grit paper, and because the paper is so tough, it removes paint faster than Granat/Brilliant/Crystal of equivalent or lower grits, and it lasts WAY longer. A Saphir disk costs double the price of a Granat disk, but can last between 10 and 20 times longer. It also doesn't clog very fast.”
“I know many do not like Rubin but I have found it to be great on bare wood at 100 - 150 gr.”
“Using Saphir P80 abrasives, it took me about 5 minutes to clean up each of about 100 fence boards.”
“One note when sculpting, because the RAS is so aggressive in any grit, I find it helpful to switch over to the 100 grit rubin for the final touches (before I move to a normal sander), you can still get pretty good stock removal with that grit, but it will leave the surface fairly smooth so you can move over to using 80 or 100 grit sandpaper right away with the normal sander.”
“Also be careful with that 24 and 36 Saphire it can really tear up wood.”
“Using my ras with 24g on red cedar left a smooth surface ready for paint! I'm not joking.”
“I do this nearly every day. When I sand a preexisting floor finish I start lower, using 36 grit, even 24 grit.”
“I must clarify I use Saphir in my shop almost exclusivity. The Saphir still gums, but not nearly as bad. I use it to clear finishes off flooring all the time.”
