- Jun 25, 2016
[size=18pt]
First introduced with the release of our MTR-X Precision Triangle, our Triangle to Guide Rail Adapter (or, Triangle Adapter for short) is now available as a standalone accessory. If you previously purchased an MTR-18 or PTR-18 PLUS Precision Triangle, you can use this adapter to convert your triangle into a large format, variable angle guide rail square. It's compatible with Festool, Makita, Kreg and Powertec guide rails.
As a special launch promo, we're offering 10% OFF on our Triangle Adapter, MTR-18, PTR-18 PLUS and MTR-X Precision Triangles! Just use promo code "TRIANGLE" at checkout.
Here's a few of our most popular products:
JUST RELEASED! MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
GRS-16 Guide Rail Squares
Our patented designs are born square through precision CNC machining and an innovative self-aligning latch mechanism. Simply slide the square onto your guide rail and lock it into place. Five seconds to square!
20mm Bench Dogs and Dog Stops
We have a dog for every job! Grab a pair for basic work holding or one of our exclusive Power-Loc and Smart Connect bench dogs—perfect for expanding your worktops or securing jigs and fixtures.
GRE-13 Guide Rail Extension
Provide more support at both ends of your plunge cuts with this 13.7-inch (346 mm) guide rail extension, which conveniently fits in a Systainer. Connectors included!
