Sword saw chains
Pedrod355
Hi All
Does anyone know the Oregon chain codes for replacements chains for the sword saw? Rather than buying direct from Festool?
Also is there much difference in the chains? Ie- is it worth getting a special chain for cutting foam? Surely the standard chain will be just as good?
Cheers
Cutting wood you will notice a huge difference in brands and tooth configuration.
you got cross cut and rip cut chains,dirty wood carbide,smooth cutting slow&fast cutting shredders.the bar used has width and length numbers relating to gauge(size) of chain,which relates to sprocket and finally the actual number of drive lengths(40's for a 12 inch bar).all these can be taken to any chain saw place to find a replacement.
My money would go with Stihl in all cases,and would bet that festools supplier is Stihl.
For soft wood one may not benefit a lot from having a carbide tipped chain, so the Stil or other makes sense.
When I talked to Rapco the fellow asked about 1/2 dozen questions.
If the foam is abrasive, etc, then it could make a difference.
As this is all they do, I suspect that they know best.
I got some chains for ironwood and rivergum, which he said, "blah-blah-blah tip style", in some special "impact grade of carbide".
I said, "OK".
They worked pretty good.
HSS is faster for the first few minutes, but after that they start smoking.
Ironwood is pretty hard though.
I have no idea the foam acts, or its qualities... and there are many types of foams.
I said, "OK".
Reason I ask is when I got my new saw it came with a Oregon chain? You would think the saw would come with a Festool chain from new
Not sure where you are located but Oregon Chain does have locations worldwidehttps://www.oregonproducts.com/pro/company/locations.htm
A location near you may have an answer for you about direct purchase, I have been in their location in Oregon in a past life working on their communication systems and can attest to the fact they do have a large technical collection of most tools that use chain to cut all types of materials, all the way up to large excavator mounted cutting tools.
