Sys-Roll and guide rails
jonathan-m
Hi guys,
I recently got a sys roll.
Now, there are slots (on both sides) where you're supposed to be able to store a guide rail. However, on my particular specimen there seems to be a small plastic ridge in the middle that prevents the rail from sliding into it.
I've attached a picture to illustrate more clearly what I mean.
I'm just wondering if other peoples Sys-Roll are the same? And a bit stomped really ???
Hello,
Do you mean that it is impossible to slide the rails into it ?
What about cut them ?
I haven't a sys-roll but I was just about to buy one and this option seemed to be nice.
welcome to the fog christophe
thats odd. presume its a manufacturing glitch.
if its solid then cut it out of the way
it can drop in a bit maybe 1 cm and then it rests on that 1 lip in the center. Not stable at all.
As you can see the outside edge is a bit taller. I'd be a lot more comfortable if it dropped in all the way down.
