Sysport Drawer Shelf Template Or Dimension
JZ Bowmannz
Hello Everyone,
I remember seeing a drawing here for the location and relative dimension of systainer's shelf (4 cut out for systainer to sit in) in the past, but I've been seaching for a while and just could not find anything.
The shelf as seen below from member Scorpion.
Would anyone have one that I can use, please?
Thanks. JZ
Here's mine...
I used a different approach - 17mm bush with 10mm cutter and a template. Knocked them out in no time at all. Used in conjunction with the SYS-AZ drawers for less frequently accessed items.
[member=1943]Garry[/member], your template validated my measurement.
I had 280mm between two feet cross and 167mm front to back. Taking out 7mm bushing off set, so they are at 273mm and 160mm. The front feet are 45mm x 38mm, so your cut out is 52mm x 45mm, and they are the Datum, the rear can run wild since they are smaller... Good simple engineering!
Thank you!
JZ
