dwillis
- Feb 21, 2008
A simple solution for all the bench dogs, Parf dogs, and accessories that have been rolling around and up to no good. Using a piece of 30 mm thick Kaizen foam from FastCap (https://www.fastcap.com/product/kaizen-foam) I cut the base piece of foam using another Festool provided foam insert as a template. Then I cut holes in the foam using a General gasket punch set (S1270) in several diameters. To cut the foam you turn and push the cutter down to the desired depth and then pluck the foam plug out. You can use a knife to cut the foam, but the gasket cutter does a cleaner and more consistent cut. There is a small amount of foam in the bottom of the hole to protect the Systainer T-LOC SYS 2 TL.
I'm also in the process of making a foam insert for a CMS-TS 75 saw insert in a Maxi-Systainer and I'll post that project when it's completed.
