Frank Pellow
- Jan 16, 2007
(part 1 of 2)
In the thread: http://festoolownersgroup.com/index.php?topic=6030.0, I talked about my design of a set of trays to be used as an alternative to Festool?s Tool Organizer Systainer 4 insert. Here are a couple of pictures from that thread showing my design:
[attachthumb=#1] [attachthumb=#2]
In that thread, I also said that I planned to see what I could fit into a Systainer 5.
In thinking about it some more, I decided to simply add a fourth tray underneath the three that I was previously using in my Systainer 4.
Then I thought even more. One of the disadvantages of the original set of trays is that the handle in the middle sometimes gets in the way of items that I want to place into the systainer.
One thing that would work would be retractable handles at the sides of the trays. For balance, two would be required. So, I looked through my Lee Valley hardware catalogue seeing if they sold anything that would do the trick. Nothing!
Then it came to me. I could fabricate each tray side with a small trapped handle that could be pulled up with one finger. Here are the components of such a side:
[attachthumb=#3]
1) The handle cut from 6mm Baltic Birch
2) The outside of the side cut from 12mm Baltic Birch. A 6.6 mm deep groove was cut into the middle and two small blocks of 6mm Baltic Birch were glued and screwed at the top edges of the groove.
3) The inside of the side cut from 3mm Baltic Birch.
The inside and outside parts were than glued together (leaving out the handle for the time being).
The tray sides were attached to the tray fronts and backs using glue and screws.
Next the tray bottom was attached making sure to trap the handles:
[attachthumb=#4] [attachthumb=#5]
In the rightmost picture above, the handles have been placed into the holes and glue has been applied to the bottom edges of the four tray sides. I don't have a picture of the actual glue-up but you can be certain that I made sure that there was no glue on the handles.
[attachthumb=#3]
