T-Loc SYS 4 Cooler Drain Hole
Bend, Oregon, USA
Just a heads up... I have several of the Red, White and Blue T-Loc SYS 4 Coolers with the liners removed, that I use for tool storage.  Some, but not all of them, have a small through hole in the center of the systainer bottom.  It appears to be about 0.1 mm in diameter.  I'm guessing that they were drilled to drain any condensation that forms in the void between the cooler liner and the systainer wall.
But, I'm not using them as coolers.  So, I plugged them with silicone to seal them.
[member=384]Scott in San Diego[/member]
Thanks for the heads up!  I also have some and I was also planning to use them for storage so I'll have to check mine.
Mike A.
For the record:
No such hole in the bottom of the Ltd. Edition Cooltainer from a few years ago.
