TDK 15.6
Mac
Hi guys,
Got the chance to pick up a lightly used TDK 15.6 drill last night for what I think was a pretty good price...being a hobbyist I can't justify biting the big bullet on a new T15+3 but this seemed a pretty good compromise. Am really looking forward to getting to play with it.
Down side is it came with only a centrotec chuck and no bits, so I need to make an order to start the collection. Any advise on a good starter kit?
Thanks a lot, fellas.
Rick
Mac, I was in the same position as you. Got me this new drill but no Centrotec stuff to put in it. So I started to look around what's available and where it's available.
I made this list for my own convenience but now that you ask for a list I might as well share it here for quick and easy reference. The prices are in euros but I thought I'd let them in for reference. You can copy and paste it to a text file on your desktop and replace the euro for UK prices.
I am in the lucky position of having Protool also here so that gives us a couple of extra choices that are preferable over Festool's choices. I don't know if you have Protool in the UK too. It is possible to order Protool from the mainland though.
I put the most basic necessities on top.
Festool
Magnet bit holder BH 60                                          492539 11,42 EUR
Lockable bit holder BHS 65 CE                                 492648  28,44 EUR
Extra long magnet bit holder BV 150 CE                  492540  22,37 EUR
Wood drill case BKS D 3-8 CE/W                              493648  46,29 EUR
Wood drill bit 10mm D 10 CE/W                               492518  14,28 EUR
Wood drill bit 3mm D 3 CE/W                                   492512    8,93 EUR
Countersink QLS D5-15 CE                                      492521  34,63 EUR
Metal Drill case HSS D3-10 CE/10                            495128  93,53 EUR
Hook driver HD D18 CE                                           492526  10,59 EUR
Countersink with depth setting BSTA HS D3,5 CE   492523  53,07 EUR
Center drill ZB HS D5 EURO CE                                492525  54,15 EUR
Protool
Bits In-SYS Bits + BHS 65 CE 19x                             637575  34,51 Eur
Drill bits In-SYS DB WOOD CE SET D4-10 5x             637574  47,60 Eur
Drill bits In-SYS DB STONE CE SET D4-10 5x             637573  44,51 Eur
The Bits In-SYS Bits + BHS 65 CE 19x by Protool is great value over buying the BHS 65 separately since it comes with a lot of bits and a nice tray that will fit in a compartment of the Sys 2 Attic model. The Protool wood drills are also better value than those of Festool because they come, again, with a nice tray while Festool's comes in a flimsy box, and they have the 10mm drill instead of the 3mm drill in Festool. All you have to buy now is the 3mm drill separately, which is a lot cheaper than the 10mm drill.
And then there's the 5 piece stone drill set, which Festool unfortunately doesn't even sell.
Oh and before I forget: I heavily prefer Wera diamond bits over those by Festool. I don't like Festool's bits at all, they slip constantly.
I did buy all of my Centrotec parts in the UK.
Anglia Tool Center is the cheapest but they do not have all the parts and Miles Tool & Machinery Centre do have them all.
The price difference is up to 50% and the shipping costst vary between euro 6-20.
Here are the (roundoff) UK prices in euro's:
Magnet bit holder BH 60                                          492539 11,42 EUR (9 EUR=-21%)
Lockable bit holder BHS 65 CE                                 492648  28,44 EUR (17 EUR=-40%)
Extra long magnet bit holder BV 150 CE                  492540  22,37 EUR (14 EUR=-37)
Wood drill case BKS D 3-8 CE/W                              493648  46,29 EUR (35 EUR=-24%)
Wood drill bit 10mm D 10 CE/W                               492518  14,28 EUR (9 EUR=-37%)
Wood drill bit 3mm D 3 CE/W                                   492512    8,93 EUR (6 EUR=-33%)
Countersink QLS D5-15 CE                                      492521  34,63 EUR (21 EUR=-39%)
Metal Drill case HSS D3-10 CE/10                            495128  93,53 EUR (not available)
Hook turner HD D18 CE                                           492526  10,59 EUR (5 EUR=-53%)
Countersink with depth setting BSTA HS D3,5 CE   492523  53,07 EUR (26 EUR=-51%)
Center drill ZB HS D5 EURO CE                                492525  54,15 EUR (34 EUR=-37%)
Thanks a lot guys, I'm trying to find my way around what's available, so this has been really helpful.  Will let you know what I end up with!
Cheers,
Rick
