Renovatedspaces
- Jan 6, 2015
[attachthumb=2]I need some advice. First off, I'm loving Festool! I bought my first one(domino) two months ago. I now own the Kapex, Carvex 420 with accessories,TS75 + two rails and 4 blades, MFK700 and the CT26 with installers cleanup kit. I'm afraid to look at my bank statement!!
So, I am rebuilding a Teak cockpit grate for a friend/client. It was originally built in 1985 and is well worn and been repaired improperly a couple times. The grate is 3/4" x 3/4" Teak. It was originally joined to the frame pieces with dowels. I would like to use dominos for the new build. I have the 4mm cutter and dominoes. What would you recommend as a minimum width stock for this application. I want to keep it as close to original width(3/4) as possible. This grate is bearing weight of whoever is at the helm! What are your thoughts? Thanks in advance!
